Part setting Gardtec 300 panel
Guest spike1986uk
Guest spike1986uk
Hi all.
I've just installed a Gardtec 350 panel and I want to do a part set routine to omit zones 1 & 3 (it's less emotionally crippling than killing the cat). I can manage omitting the zones manually but my missus is not very logical.
The problem is the installation manual, I can't make head or tail of the part setting bit.
Can anyone help please?
Spike.............
The part setting is programmed when you set up each zones attributes.
EG: Setting the front door as 0114, would mean you have set up zone 01 as an E/E zone with the chime enabled.
set up the zones you require to be part 1 omitted with the last zone attribute as 1, EG:If i were to program zone 3 with 0311, this would make zone 3 an Entry/Exit zone that is removed when the system is part 1 set.
Guest spike1986uk
37124[/snapback]
Thanks for the info. I understand the manual a little better now.
I'll give it a whirl tomorrow
