Service Engineer Posted January 14, 2005 Posted January 14, 2005 Anyone know what the error message E-5 indicates on a Panasonic TL300 VCR ..? ........................................................ Dave Partridge (Romec Service Engineer)
norman Posted January 14, 2005 Posted January 14, 2005 Tape jam? Nothing is foolproof to a sufficiently talented fool.
Garry Posted January 14, 2005 Posted January 14, 2005 Theres a manual in p.d.f here..... http://www.steve2shirts.co.uk/en-gb/pg_21.html Hope it helps..... Garry You can lead a horse to water but you carnt climb a ladder with a bell in both hands.
Rich Posted January 14, 2005 Posted January 14, 2005 E5 is there but a bit vague. Its either the capstan belt fallen off, broken or old and worn. whip the bottom off and you should see the belt. If not it could be the mode switch. They are the most common, other than that its carriage faults and the odd loading belt that causes a problem.
Service Engineer Posted January 14, 2005 Author Posted January 14, 2005 guys, its an old thing probably not worth repairing. Just thought i`d ask about the error message incase it was something simple, I`ll have a look at the capstan belt when next on-site. ........................................................ Dave Partridge (Romec Service Engineer)
Brian c Posted January 15, 2005 Posted January 15, 2005 Tape jam? 37130[/snapback] as norman says, it's usually a tape error (mechanism) even when you remove the tape it sometimes won't clear. Send it off for repair unless you're good with that kind of thing Ok, next time I'll read the whole thread! If you don't know......ask.
Nova-Security Posted January 15, 2005 Posted January 15, 2005 E5 is there but a bit vague.Its either the capstan belt fallen off, broken or old and worn. whip the bottom off and you should see the belt. If not it could be the mode switch. They are the most common, other than that its carriage faults and the odd loading belt that causes a problem. 37135[/snapback] Go with that carriage fault, used to do onsite repairs with new belts also it could be the pinch rollers are worn. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Garry Posted January 15, 2005 Posted January 15, 2005 Like it Monteey like it allways on the upsell nice info Rich.... Garry You can lead a horse to water but you carnt climb a ladder with a bell in both hands.
