Optima XM
Guest Steve Brough
Guest Steve Brough
steve@thebroughs.com
I've got an Optima XM panel and the internal speaker has blown. Can anyone point me in the direction of a supply for a 5cm (2 inch on old money :D ) speaker that has a 32 ohm impedance.
I've checked companies like RS Components, but they don't stock any 32 ohm speakers. I didn't want to use a smaller value since I'd be overdriving the audio amplier in the panel.
Any suggestions greatly received (and before anyone suggests it, I'll replace the panel as the last resort ;) ).
Thanks in advance, Steve Brough
The Optima XM will be fine with a 16ohm speaker (in my experience anyway). But if you are not happy with that, why not put in two speakers and wire them in series.
But I have never had a problem using a 16ohm speaker on an Optima.
Guest Steve Brough
Thanks for that. I'll go searching for some 16 ohm ones as well now :)
Try Maplins, but If you get really stuck, PM me your address and i`ll post you one.
I did some research on their web site but they don't give the impedance values,
so I visited them, and they only sell 4 & 8 ohm speakers.
I've also tried Farnell, and RS Components but no luck. :(
If you mail me at steve@thebroughs.com and I'll reply with my address and let me know how much you want for it.
