Concept System P A connection help
Guest Guest_STEVE_*
Guest Guest_STEVE_*
My alarm system is a 4 zone concept system ( this is what it says on the panel cover). It has a separate keypad and is approx 12 years old.
Today I decided to add a panic button to the system however, when I came to wire it up to the panel there seems to be no P.A connection on the PCB :no: Could anybody please inform me if there is another way of wiring the panic button up so it will work.
The PA connection is in the Keypad :blink:
Guest Guest_steve_*
thanks i have noticed that there is a attack led on the separate keypad do i just pull the cover and connect it inside the keypad cant look now kids in bed
37201[/snapback]
Yes, - you'll probably find a link in the PA terminals, which you'll need to remove, but be prepared for the tamper to go off when you pop the keypad. ;)
ARJ
A nearly retired previous installer !
