Guest m1ne5h Posted January 16, 2005 Posted January 16, 2005 I have a concept alarm system which has lost its settings, as I removed the fuse to the control box. I have been advised the battery needs to be replaced, but also the system needs to be reprogrammed. I have an engineering guide for the concept 6, is all that needs to be programmed the entry and exit times? the customer code etc? If there is more to it, can someone recommend anyone in the NW London area? Thanks in advance
Guest simmo Posted January 16, 2005 Posted January 16, 2005 Give Colin from Alarmgard a ring he is right on your doorstep. Colins website Simmo
