Installer Lockout
Guest incognito
Guest incognito
This has probably been talked about a few million times, but here it goes again. Is there anyone that knows how to default a DSC installer lockout for a 632, 832, or 864? I have searched everywhere.
Please help.
Information on engineering functions, especially defaulting panels, will not be given out on this forum, sorry
37336[/snapback]
In this case it couldn't be shared anyway because there isn't any way to reset the panel if installer lock option is set.
  • 1 month later...
Guest paquillo
Hi,
You can only try if the previos installer had forget at default values any system protection code like a downloading access code. If you can access via downloading software you will can to reprogram the system, if don't, this installation will be lost.
