Scantronic 9448+
Guest chrisbryce
Guest chrisbryce
Hi all,
i have had a full installation 12 months ago which has 3 internal sensors. Ive had no problems at all but i would like to temporarily disable each sensor over the next 3 months so i can move them to redecorate. I also at some point need to move the main box and key pad. I have the manual which says i can switch off the zones but im uncertain if this will allow me to move the sensors.
Is there a procedure for eliminating a PIR ? will i have to call in the installer to move the main box anyway?
any suggestions please
Many Thanks
Chris
Chris, you will have to contact the installer to move equipment.
Every device is protected by a 24hr tamper circuit and you will probably invalidate your service agreement should any gear be moved.
Regards
Paul
PG Security Systems
Somerset
SSAIB Certificate of Merit Installers.
www.pgsecurity.co.uk
