Guest Ivano Posted January 18, 2005 Posted January 18, 2005 I have a Scantronic system 9600 with two keypads. One is broken and my technician told me that it is not repairable, so i found one Scantronic keypad 9930. The seller told me that it is compatible. Can you please confirm and if it is necessary to make some modification to the system to connect 9930 or other suggestions? Thanks for your reply.
Paul Giles Posted January 18, 2005 Posted January 18, 2005 Who told you its compatible? As far as i know the 9600 is only compatible with 9625 keypads The 9930 has four terminals compared to the 9625 which has three, and the panels are completely different. Now which seller was this? ebay user no doubt!? Let us know the details, always good for a laugh the 'pros' on ebay are! PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
Guest Ivano Posted January 21, 2005 Posted January 21, 2005 Do you think i must replace the entire system?
Mister_Dave Posted January 21, 2005 Posted January 21, 2005 Not the entire system, just the control panel. I would Suggest calling a pro. Dave Oxendale York based security systems engineer.
Paul Giles Posted January 21, 2005 Posted January 21, 2005 Scantronic do an upgrade kit for the old panels, we upgrade quite a few and they will fit the old 9800, 9600 panels etc. You get a new keypad with the kit (9930) so you will just need to buy another 9930 for your system. This is of course work for the professionals so it makes me wonder why your 'technician' wasn't aware of this? Paul PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
puma2000uk Posted January 21, 2005 Posted January 21, 2005 HI Iveno I have a hardly used 9600 with 2 keypads you can have for £60.00 if you are interested??
Nova-Security Posted January 21, 2005 Posted January 21, 2005 HI IvenoI have a hardly used 9600 with 2 keypads you can have for £60.00 if you are interested?? 37568[/snapback] www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
