Guest serge Posted January 18, 2005 Posted January 18, 2005 Which module do I need to connect 2-wire conventional smoke detectors to an analogue addressable loop? Perhaps it should be M201E?
Guest Adrian Posted January 22, 2005 Posted January 22, 2005 B) Ok this is out of my area is this a fire alarm Question? Adrian B)
Adi Posted January 22, 2005 Posted January 22, 2005 Which module do I need to connect 2-wire conventional smoke detectors to ananalogue addressable loop? Perhaps it should be M201E? 37356[/snapback] M512ME. I really can't be ar**** with it anymore.
Guest briframpton Posted January 23, 2005 Posted January 23, 2005 which system do you want to connect the conventional detector to (make)
Guest Posted January 28, 2005 Posted January 28, 2005 At least you have some "Made in Finland" products there!!
