Guest IM_Alarms Posted January 20, 2005 Posted January 20, 2005 again guys, i'll track the data install fellow down as Lurch suggests and maybe just twist his arm up his back a bit. At least I am better informed now...................... I am aren't I?
Guest Posted January 20, 2005 Posted January 20, 2005 At least I am better informed now...................... I am aren't I? 37482[/snapback] Course you are! If you need a pro to come down and do the job shout up.
Garry Posted January 20, 2005 Posted January 20, 2005 Youre not the only one I.M I think its been a good interesting topic Ive deffinatley learned more.... Garry. You can lead a horse to water but you carnt climb a ladder with a bell in both hands.
ian.cant Posted January 20, 2005 Posted January 20, 2005 Have you considered getting the DVR People? Maybe they will come to site and help you sort it, most larger suppliers/manufactures would probably help out.
Guest IM_Alarms Posted January 20, 2005 Posted January 20, 2005 That is what the Forum is for after all, I'll keep you informed if I win the job. Quote is in the post as we speak......... Ta again all.
Guest Posted January 23, 2005 Posted January 23, 2005 This is EASY job. There is no need to link four networks together to access the DVR. Only thing you have to do is to make the DVR as fifth network and put it behind firewall. Then you make accesslist into firewall which accepts only configured IP addresses. you need: 1x Firewall (less than 1k
Guest Posted January 23, 2005 Posted January 23, 2005 2 things Keke; 1) I think you've misunderstood somewhere. The objective is to restrict access between the four networks, not between the DVR and the network in general. 2) Where do you buy your firewalls from? 1K is way over the top for this application.
Guest IM_Alarms Posted January 24, 2005 Posted January 24, 2005 Perhaps he means ' Fireplace', you know how cold it gets out there in Finland.!!
Guest Posted January 25, 2005 Posted January 25, 2005 2 things Keke;1) I think you've misunderstood somewhere. The objective is to restrict access between the four networks, not between the DVR and the network in general. 2) Where do you buy your firewalls from? 1K is way over the top for this application. 38012[/snapback] 1) YES, EXACTLY! The objective is to restrict access between the four networks, not between the DVR and the network in general. I understood that those 4 networks ARE separated from each others already. So we allow traffic from those networks to DVR, but not from anywhere else. Thats why the firewall is needed. With switch (which _MIGHT_ be needed ) we connect all 5 networks together and to Router (Gateway to internet). 2) I buy them from hardware store. Of course you can by a cheap DIY firewall if you want to..
