Guest stugrip Posted January 23, 2005 Posted January 23, 2005 Hi I am new to the forum and a novice diy. I installed my A1 (Ex B&Q) AJ600 some 10 years ago. It would appear the board is now faulty and i need to replace the control box. I have read previous posts on this site to realise that there has been some disscussion on this subject. I am a little confused but i have seen a recomendation to replace the box with a Texecom Veritas 8. Is this the correct thing to do? I have found 1 avail £39.95 online electrics on E-Bay. can you advise stuart
morph Posted January 23, 2005 Posted January 23, 2005 Texecom veritas panel will do the job, I would reccomend that you consider buying a new external bell box also. Change the batteries also. Colin.
Guest stugrip Posted January 23, 2005 Posted January 23, 2005 Thanks Colin I will replace bell box and battery as you suggest .
amateurandy Posted January 23, 2005 Posted January 23, 2005 If buying on eBay make 100% sure that it comes with the installation/engineering manuals as well as user instructions. :!:
Guest stugrip Posted January 23, 2005 Posted January 23, 2005 I have found a company local Essex Electrical will phone them in the morning http://www.essexelectricalwholesalers.co.uk/
