concept 6
Guest Guest_adam_*
Guest Guest_adam_*
:realmad: i just wounderd if any 1 can help with me few teething problems when i set the alarm and go out it starts beeping and sets but when i open the door is it ment 2 start beeping till i turn it off cus there is no noise at all and me need a bit of help programing the zones into the memory and sorting me entry and exit out it probably needs seting back up on the panel its amazing wot a few digits do its probably that old non of you will no the rest all works fine all help would be apriciated :w00t:
Guest Guest_adam_*
has any 1 got the user guide for the concept 6 or the xm4 or xm6 i have been told are the same look forward 2 hearing from some 1 soon thx :yes:
