concept 6
Guest Guest_adam_*
Guest Guest_adam_*
:realmad: i just wounderd if any 1 can help with me few teething problems when i set the alarm and go out it starts beeping and sets but when i open the door is it ment 2 start beeping till i turn it off cus there is no noise at all and me need a bit of help programing the zones into the memory and sorting me entry and exit out it probably needs seting back up on the panel its amazing wot a few digits do its probably that old non of you will no the rest all works fine all help would be apriciated :w00t:
TheCrazyFrogIsJG.mp3
The Concept 6 has fixed / non programmable zones ( zone one = ex/ent, zone 2 = intermeadiate etc).You could do with the user guide ( there is one or more on this site , try the XM4 or XM6 , same as) this will explain how to omit zones and do a walk test to test your sensors.
Regards,
