Monteey Posted January 29, 2005 Posted January 29, 2005 anyone had exp' with the pyronix(sorry) vocaliser??sems cheap but is it cheerful Yup ive fitted a few of them, actually not a bad piece of kit, Pyronix must have had a good day when they thought of that one, of course everything Pyronix has its faults, and the vocaliser's is the fact that the case it comes in gives virtually no room for cabling, very poor design, however the unit itself works well, mics pick up a pin drop although will only let you listen in for 15 secs at a time. Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Posted January 29, 2005 Posted January 29, 2005 Yup ive fitted a few of them, actually not a bad piece of kit, Pyronix must have had a good day when they thought of that one, of course everything Pyronix has its faults, and the vocaliser's is the fact that the case it comes in gives virtually no room for cabling, very poor design, however the unit itself works well, mics pick up a pin drop although will only let you listen in for 15 secs at a time. 38718[/snapback] i thought that swearing words were forbidden??
