Door contacts or PIR's
Guest Chewie
Not all systems in the UK are installed with eol wiring Georg.
39552[/snapback]
Nor here.. Not even in goldsmith stores installed by cowboys... :w00t:
Using DEOL just saves you from many troubles.. :whistle:
Thanks for the explination monteey
Is there a colour convention that installers use for the cable.
I was thinking Red +13V, Black 0V, Blue and Green for the Switch and Yellow and White for the tamper.
But if there is a conventinal colour code to follow, I may as well follow it.
There is no set colour code , for obvious reasons . I would suggest using red + black as the power though , saves any blown fuses.
39703[/snapback]
thats nearly the same colour code I use for installations. :rolleyes: As far as I know each company uses its own color code. Makes sense to me since it´s harder to sabotage the alarm system when you can´t be sure how the cable colours are used.
cheers,
Alex
Just as a little tip I would advise not using red, black ,blue or yellow as power. This enables all tamper and zone colours to be the same even with unpowered detectors.
I agree with Breff. And Monteey please dont mention piping :cry:
Exactly Monteey, if you use green and white for power, you wont send 12v down to a contact run in 4 core.
