Patch Panel Connections
Nova-Security
OK, the other way then, if you're using secondary mod-taps, is to connect pin 3 of the master socket (white\orange) to pin 2 on the patch panel (orange) in addition to Simons connections.
If you've got master sockets that then feed the patch panels you've got to use slave/extension mod-taps to plug your phone cable into.
Best to get your multimeter out on the mod-taps and verify that they're wired up to carry the ring signal, and on which connector. Then just wire up the other end the same.
38794[/snapback]
You need to check, I have come across secondary mod-taps where there is no connection to RJ45 Pin2 internally and hence the bell-wire is not passed. Best tyo check before rewiring it in.
Simon
ToneTel Telecom
www.tonetel.co.uk
By the way, Mod-Tap is a manufacturer of all sorts of stuff and is now Molex.
To quote their web site:
"MOD-TAP (now known as Molex Premise Networks),"
The devices you want are actually called LAU's (Line Adapter Units).
Se, for example, these sold by Inmac. RJ45 to BT adapter
I wondered if anyone was going to mention the mod-tap\LAU thing!
Regarding the REN, most modern handsets are actually well under ! so you can quite easily go way past 4 and not suffer any problems. Just stop adding phones when they don't ring any more!
I agree lurch about the REN but you will be amazed how many faults I do a week regarding the REN. The worst offenders are Binatone, Samsung, and the Panasonic DECT types. Also allot of the older Phillips DECTs gave a lot of problems It also doesn
I wired a huge house recently, and installed a 48way patch panel. We also fitted a small (4-16) PBX, and patched this to the panel.
Direct lines from the NTE where patched to outlets aswell, using secondary modtaps.
I will try to find the numbers we used. We had a patchpanel wired with the RJ45's with the 16 exn's, and the direct lines, so these could be patched to the panels above.
Email : martin@askthetrades.co.uk
38856[/snapback]
But.. remember some telephones have a built-in capacitor so do not require the bell wire (whether is is passed through or not), seem to remember a lot of Interquartz phones have this.
It is definetly RJ45/Patchpanel terminal number 2 (orange) which cross connects the bell wire from terminal 3 in the LJU or direct from NTE5a. Just as long as the Mod-Tap/LAU supports it.
Simon
ToneTel Telecom
www.tonetel.co.uk
