panel reset
Guest ivorbigtool
Guest ivorbigtool
my mates control panel went wrong after decorater knocked pir sensor he has phoned enginer who installed it who wants 60 quid to come out and reset panel. the cover has no name on it but the board has TEXECOM 1995 PC009-4 so can anyone help from this or give me a reset code via email...
£60 is not expensive for getting an engineer to attend on a Sunday. There may be more wrong than simply needing a reset code.
Only the installer will know the reset code. Your gonna have to bite the bullet and pay the man. Anyway whats £60 compared to losing the lot if the alarm isnt working properly. After all thats why he had it fitted isnt it?
If it just requires a reset after tamper (engineer reset no enabled) you may have not reseated the tamper spring correctly, I would re check, enter the user code and press reset, otherwise as above.
38807[/snapback]
unless its been installed to EN regs :w00t:
Trade Member
  • 1 year later...
Guest Pedro Azevedo
The board PC009-4 have 4 jumpers in the right side. May be there is a way to reset the board and restore it to the default features. I
I heard leaving it in your freezer overnight works
Not if its wrapped in 4 jumpers. :P
