Powering speed domes
housty
Hi All
What is the standard type of cable you would use to power speed domes?
I use alarm cable for 12v cameras would i still use this???
Housty
Houston Security Systems Ltd
Intruder alarms
CCTV
Door entry
Fire protection
Networking
SSAIB Approved
Which dome type and where are you fitting the PSU Locally or Remote what distance is involved?
I take it you are ok with the data cabling?
I am fitting the PSU in a switch room about 20m - 30m away and the cameras are JVC
housty
Intruder alarms
CCTV
Door entry
Fire protection
Networking
SSAIB Approved
JVC reccomend that use a cable of 1mm or greater diameter for up to 100metres, I would use a two core flexible mains type cable.
if your psu has output for dome and heater i would use 1.5mm 4 core mains flex. A pair for each, that way if you loose one u wont loose the other.
chris
Trade Member
chris
38980[/snapback]
and i would use 2.5mm 40 core mains flex. A (couple of) pair ('s) ( and few extra :D ) for each. that way if you loose one ( ore ten ) you wont loose the rest.
houhou
any cable somehow flexible will do if its cores has enough diameter. 1.5mm2 is enough indeed with cable lenght of 20-30m
housty.. from where are you? didn't know that meter is an imperial unit..!!??
:question:
and you would need a team to put it on the cable jacks and run it off. :lol:
40 core :whistle:
.75 is probably the biggest I would use, Really you want to look at the maximum current drawn from the device you are powering, and the maximum current the power supply can provide then use a suitable cable to carry the power.
I'd probably use 2 or 3 core .5 or .75 flex.
40 core :whistle:
38996[/snapback]
but at least i would have some spare ones.. just for case.. like tsunami or plain earthquake.... or crazy Finn........ or .... - something..?
and you can always put all the shoot on to apprentices :lol:
F.. next time i'll make it 400 core.. :blink:
The manufacturer reccomends:
If you dont use the cable that the manufacturer specifies as a minimum, you will get into warranty problems if it ever goes wrong.
