Lectrician Posted February 2, 2005 Posted February 2, 2005 Tried to post a question in the Fire Alarm section, but can't. Hope it's ok to here. I have to link the firealarm in a pub to the extractor fans in the kitchen. Alarm sounds, trips the motor starter. Easy to do using the aux relay contacts in the panel, and the panel 24v supply to power a relay. (which will open the contacts on the fan starter). Ok, the question..... Does the cable from the panel to the relay ( which will be in a gewiss box approx 5m away), have to be FP or similar?? Email : martin@askthetrades.co.uk
ian.cant Posted February 2, 2005 Posted February 2, 2005 Does the cable from the panel to the relay ( which will be in a gewiss box approx 5m away), have to be FP or similar?? I am 99% sure it does, but it wouldnt hurt to use it anyway!
Lectrician Posted February 2, 2005 Author Posted February 2, 2005 No it doesnt have to be be in FP but obviously is good practice to run it in FP. 39155[/snapback] guys. I was thinking that if I was using the panel 24v to feed the relay, if the cable suffered fire damage, the panel fuse would blow = no sounders! Email : martin@askthetrades.co.uk
Lectrician Posted February 2, 2005 Author Posted February 2, 2005 24v AUX is separately fused generally 39158[/snapback] That makes sense Email : martin@askthetrades.co.uk
Guest Posted February 2, 2005 Posted February 2, 2005 Does the cable from the panel to the relay ( which will be in a gewiss box approx 5m away), have to be FP or similar?? 39152[/snapback] Depends who the fire officer is, but good practice says yes. I've linked relays from fire panels to intruder alarms before and FP has been specified even though it is just connected to a standard relay in a plastic box at the other end.
Adi Posted February 3, 2005 Posted February 3, 2005 Ive done that on addressable systems, FP from output unit to contactor then standard mains cable there after. I really can't be ar**** with it anymore.
Brian c Posted February 3, 2005 Posted February 3, 2005 I thought only the sounders had to be FP? If you don't know......ask.
Guest Posted February 4, 2005 Posted February 4, 2005 I thought only the sounders had to be FP? 39276[/snapback] Technically yes, but it's usually easier to wie it all in FP than try and convince the person who drew up the spec any different than they have decided. I think in general everyone wires the complete fire alarm in FP, I always have and I'm not one for doing unneccesary work. It's just become one of those done things.
Brian c Posted February 4, 2005 Posted February 4, 2005 It's just become one of those done things. 39281[/snapback] Agreed If you don't know......ask.
Paul Giles Posted February 4, 2005 Posted February 4, 2005 All cabling and associated cabling MUST be in FP, not allowed to use red twin and earth anymore for call points etc. PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
