Veritas 8C Lockout
Guest ChrisG
Hi,
The veritas 8C that I installed some years ago has locked out following an interruption in the electricity supply. It will now not accept any input on the keypad, User or Engineer, the power button is not illuminated but there is power to the unit as it alarms when power is removed.
I have lost the installation manual so I am stuck as to what to do, I know I can't get an installation manual after reading previous mailings, any ideas?
Thanks
Chris
It sounds like you may have a popped fuse on the dc output side, probably due a a standby battery thats way past its sell by date. Best advice would be to call out a local firm (i assume its not under maintenance).
You could post your location and maybe we have a an engineer nearby on here who can help you out.
hi i just had same problem on optima xm, following power cut, i turned of the mains power, opened front pannel and disconected battery, then reconectd mains power and battery all allarms went off then i was able to input security No and all was ok. worth a try.
39486[/snapback]
But this doesn't cure the dead battery..
