Brian c Posted February 6, 2005 Posted February 6, 2005 I don't seem to be getting very far with this query, with the exception of the helpful reminder about using a laching PIR.Please note that I cannot replace the four wire between the alarm panel and the outbuilding - I am stuck with it. What I need to know ishow to wire a PIR and two door detectors with a four wire cable. The crux of the question is how do I get power to the PIR? Any help would be greatly appreciated. 39412[/snapback] Do you have mains in the outbuilding? I'd do what Eng suggested, fit a slave panel in the outbuilding and use the 4 core to trigger your main system. If you don't know......ask.
Guest Posted February 6, 2005 Posted February 6, 2005 I don't seem to be getting very far with this query, with the exception of the helpful reminder about using a laching PIR.Please note that I cannot replace the four wire between the alarm panel and the outbuilding - I am stuck with it. What I need to know ishow to wire a PIR and two door detectors with a four wire cable. The crux of the question is how do I get power to the PIR? Any help would be greatly appreciated. 39412[/snapback] Wire 1 = +12V Wire 2 = 0V Wire 3 = PIR contact Wire 4 = Door contact use double end of line resistors. what kind of DEOL does your panel support?
Guest Posted February 6, 2005 Posted February 6, 2005 Please note that I cannot replace the four wire between the alarm panel and the outbuilding - I am stuck with it.What I need to know ishow to wire a PIR and two door detectors with a four wire cable. The crux of the question is how do I get power to the PIR? Any help would be greatly appreciated. 39412[/snapback] I think the only realistic, and compliant, option would be as Eng and Brian suggested and fit a slave system in the remote buildings. I doubt that your existing panel will support iD or DEOL so that'll be a hefty upgrade charge. Using the 4 core to wire the PIR and contacts from the existing panel without additional equipment is classed as a bodge in my eyes, and probably everyone elses here.
Guest Posted February 6, 2005 Posted February 6, 2005 Using the 4 core to wire the PIR and contacts from the existing panel without additional equipment is classed as a bodge in my eyes, and probably everyone elses here. 39431[/snapback] indeed
ARJ Posted February 8, 2005 Posted February 8, 2005 I don't seem to be getting very far with this query, with the exception of the helpful reminder about using a laching PIR.Please note that I cannot replace the four wire between the alarm panel and the outbuilding - I am stuck with it. What I need to know ishow to wire a PIR and two door detectors with a four wire cable. The crux of the question is how do I get power to the PIR? Any help would be greatly appreciated. 39412[/snapback] Now that the cable is in, other than the alterantive options suggested, (i.e. Slave systems etc) the only way is to use two cores for the 2 doors and the other two cores for the PIR. Provide the 12v power from a local PSU in the new barn and tamper-proof the cores by using End-of Line's, - if the panel will support them. However, if the main system is looked after by a local company you'd be better letting them do it and do it their way, as the panel may then still need some extra programming for the new zones. Also there may be a warranty issue if you start fiddling ! Alan ARJ Security A nearly retired previous installer !
Guest Posted February 8, 2005 Posted February 8, 2005 Now that the cable is in, other than the alterantive options suggested, (i.e. Slave systems etc) the only way is to use two cores for the 2 doors and the other two cores for the PIR. Provide the 12v power from a local PSU in the new barn and tamper-proof the cores by using End-of Line's, - if the panel will support them. However, if the main system is looked after by a local company you'd be better letting them do it and do it their way, as the panel may then still need some extra programming for the new zones. Also there may be a warranty issue if you start fiddling ! Alan ARJ Security 39849[/snapback] better off fitting a slave
norman Posted February 9, 2005 Posted February 9, 2005 or fit a system in the outbuilding and use the 4-core to trip a zone on the main system 39372[/snapback] *quoted for agreement. Nothing is foolproof to a sufficiently talented fool.
daiashthomas Posted March 23, 2005 Posted March 23, 2005 slave system is best idea by far atm Trade Member
whistle Posted March 23, 2005 Posted March 23, 2005 it you fitted a psu in the barn and used it for power you would not have enogh cores as you would need a common neg to the main panel.
ian.cant Posted March 23, 2005 Posted March 23, 2005 it you fitted a psu in the barn and used it for power you would not have enogh cores as you would need a common neg to the main panel. 45393[/snapback] Only if you needed to power a rio or other type of expander, you dont need to common the neg's for PIR's or other powered detection devices only.
