Quotes
Lectrician
Not sure if this is allowed on this site....
How much, roughly, to install a Panasonic 206e (readily available to even DIY'ers I beleive), with 4 extensions. 3 system phones, bottom of range, and 1 with display.
Cables where already installed (I put them in, but had connected them all to PSTN ready for a PBX).
I didn't get the job to install the PBX as I was too busy, but was shocked at the price I saw on the invoice from the other company!! I have just attended the site to connect a second line, as BT couldn't install the second line until after the other company had left.
Email : martin@askthetrades.co.uk
Without seeing the job, dunno. Maybe if this was in the trade section it might get a respose?
As Luch said i would quote on seeing the job, depends if they want all the features programmed up, professional recording on the DISA/Auto Attendant card etc but my prices would be around below if south-east customer:
KT-T206e CCU at £275
1 x KX-T7730 Display keyphone at £140
3 x KX-T7750 keyphones at £270
Install-Commisioning around £150-200 (inc 1-year maintenance)
Wiring Charge about £25-50 if all cables run and in place, just needing DDK connectors for system and sockets connected.
This is rough estimate though without seeing the job, I also would have popped back for free and enabled the 2nd line if Bt were late supplying it - but this would only be for in-house work, not if doing trade engineering for another firm.
I am always interested in charges, what did the other firm charge, cannot see anyone charging more than £300 for KX-T206 install/Commisioning.
Simon
ToneTel Telecom
www.tonetel.co.uk
I don't know the break down, but the total was £1,3*****ish.
Steep?!? The bloke was there for a part day only! No maintenance contract!
39946[/snapback]
Very steep !, sounds like big company prices, but still steep as the bigger companies normally get better trade price on the kit. They probably have a fixed price of £40-50 per point whether its a 30m run or just wiring a socket to a pre-wired cable. Still after the sale of kit, look like the installation charge was over £600 - this is a rip-off.
For £1300 I could have supplied and installed a BT Pathway 818 (as 2+6) with 4 handsfree featurephones including years maintenance and if prewired cables, could have maybe saved them a hundred or 2 hundred kit !
Still good that companies like this in the game, as you don't even have to try to beat their prices !!
Regards
Simon
ToneTel Telecom
www.tonetel.co.uk
