lock on pvc door
mikeald
hi there, i need to fit an intercom on a house with a pvc door. can someone please tell me how i can fit a rim release to a door like this?!!!! will i need a lockie to fit a yale lock for me? and then i can just 'pack out' the receiver?
cheers
mike
Intruder & Fire Member
40162[/snapback]
Dont mess about fit a Mag Lock.
Trust me i did this rim thing years ago and by the time i had finnished i swore that i would only ever use mag on UPVC. Their not pretty and occasionaly wont fit so consider drop bolt or the most proffitable way if your not sure DONT DO THE JOB
Jef
Customers!
Guest Peter James
Or you could do what we do sub a locksmith to do it, that way when it goes out of line (and it will) they have to go and sort it for free not you.
Pete
sounds too complicated! wont bother with this one. cant fit a mag lock, as an egress button is not an option.
cheers
Guest Peter James
Theres always a request to exit pir !
cant fit a mag, as customer needs to use a key outside. surely there is an easier way to solve this?
40305[/snapback]
http://www.adamsrite.co.uk/Access-Control/acc7100.htm
But you will need to swap the full door lock to one that has a dumb handle on the outside and the key opens the latch
Its not cheap and will not work with all upvc doors
40321[/snapback]
The boss speced a job a few years ago we ended up getting a locksmith to do that, cost us more than the job was worth. Plastic doors we always fit maglocks now.
Trade Member
40423[/snapback]
It dose help if you are a locksmith as well ;)
