£200 budget
Guest GMV
Hey I guess im gona get flammed for asking his here, but ask I shal.
I want a budget house alarm.
I have very small budget as alarms go, of (£200) & I guess something is better than nothing.
I have the ability to do a hard wire alarm myself if I go down that route.
I want a bell box/control panel/ 2-3 pirs & 2-3 contacts.
Looking around diy shops at my options there & they all seem to be wirefree kits (solar one I cant have as need the box on north facing wall).
What are my best options? I cannot go above 200.
I had been offerd a new yale kit 4 (HSA3800) wirefree for £140, which is what got me thinking about getting an alarm in the first place, is this worth it? or am I throwing money away?
cheers in advance for all the smart replys!
Garry
First off, don't even think of wireless unless you're spending a decent amount of money having someone install a professional wireless system.
Try and find somewhere, either online or from a local electrical wholesaler, that will do you a kit with most of what you need. This will probably come with pretty much everything required for £200 or less, and will probably use better components than B&Q are trying to palm off on you. They will normally be based around an entry level panel such as an ADE Optima or a Texecom Veritas.
I personally would recommend you get an alarm professionally fitted though.
Here we go again Lads!! :cry:
Look at the reality.
You wanna spend £200 to protect your house and belongings that cost tens of thousands of pounds if you add them all up.
Honestly,Do yourself a favour and save a bit more money. £600 should get you a good system thats fitted and maintained buy a proffesional.
Chris
Trade Member
Alternatively if your ok installing yourself give StrikeSecurity a call, he can probably supply all the kit for your budget.
www.strikesecurity.co.uk looks like his site is down at the moment due to a re-design but contact details are shown.
if you must do it DIY then dont forget ebay
Hmmmm..?
Are you serious..? The only stuff I `ve seen on eBay has been either second hand or the sellers source has seemed debatable..
This Texecom Excell kit looks just the job, and only very slightly over-budget (£213.03) with the VAT added.
Excell Kit.
Hmmmm..?
40403[/snapback]
There's some interesting stuff occasionally, a few weeks ago I saw a pair of Luminite external PIRs (brand new) which went for about a fiver each, RRP is aout £70. Not a bad saving!
Go with Service Engineers recommendation of the Veritas Excel kit.
