£200 budget
Guest GMV
Wow thanks for all the replys! I went to bed last night with 1 reply (straight away) & today I have 9!!!
First off, After the reply from Lurch, I today went to TLC (elec wholsale)as I work around the corner from on branch, to see what they have on offer.
They sell a kit comprising of optima compact R+ panel, 2x pir's , 2x mag contacts, bell box, back up bat, 100mts 6 core/clips & panic button for 99+vat, extra pir's 12.99 , remote pannel 17.25...see here
http://www.tlc-direct.co.uk/Products/TSPRO1.html
I quite like the idea of a dialer ( cheap one of course) as I work 2 mins away from where I live, so could be on the scean in that time if I had the call.
What are your thoughts?
The Texecom Excell kit Recommended by Service Engineer also looks a good deal which I could stretch to?
any one had any experiance of either kit? any pitfalls?
Thanks again.
G
40501[/snapback]
Aww, you took it with you?! ;):D
40501[/snapback]
You get what you pay for and that is cheap! However, it will do the job it's designed to.
Thanks again.
G
40501[/snapback]
If you can stretch to the Texecom then do so. They are of general better quality.
If you don't know......ask.
40501[/snapback]
When you say cheap, I assume you've seen the cheap ADE Informa, don't even think about it, it's ****. If you're going to get one you'll unfortunately have to shell out for a decent one, such as the Texecom one.
40501[/snapback]
The Excel is about as far down the chain as most professionals would go, below that and you're into DIY stuff. The Excel is a good panel, some nice features and relatively easy to fit. The PIR's in the kit are good too.
Ok , looks like the texecom it is! I am guessing that I can add a dialler at a later stage with out too much hassle.
Also can I add a dialler from another manufacture? like I said I'm on a budget & should a decent one come up on Ebay before I have enough spare cash for a Texecom one, should I go for it?
Thanks All.
Off to bed now & once again Lurch is in the foremost in my mind!!!! :wacko:
Now im worried!
Ta
G
40509[/snapback]
Yes, while you're wiring everything up just get a phone line into the area of the panel and leave it disconnected. You can just add it in later.
40509[/snapback]
You can add a dialler from any manufacturer but the only ones that are any good are the Texecom ones or the Menvier SD1+ or SD2. The Texecoms are easier to get hold of if you're not trade and do the job admirably.
Now im worried!
40509[/snapback]
Er, thanks. Don't think I'll be sleeping tonight!
Alternatively, why not contact a local professional and ask him to 'Supply only' enough kit to match your spec, to a budget of £200. That way you'll get some professional kit, with everything you need rather than DIY stuff and find you're missing something essential when you come to fit it.
I would have thought, that using a Scantronic 9448+ 'on-board' control panel, some reasonable PIRs (perhaps on offer at the wholesalers) and all of the other bits you'll need, (except the dialler) he'd be happy to supply for £200.
I'd also go with the Texecom Dialler for ease of programming as a DIY-er, as and when you can afford it. Or push the boat out for an extra £15 (ish) and get the additional SMS Text facility with it.
However, remember if he supplies it for £200 and you can't satisfactorily install and program it, he's not going to come and sort it all out as a favour.... Also, don't expect to get a bell-box with his logo on it, if he's not installing it !!
Alan
ARJ Security
A nearly retired previous installer !
Guest Peter James
Alan
ARJ Security
40523[/snapback]
Good Advice ;)
And talking of good advice buying from an installer means that thats what you will get from him, you wont get that from somewhere like Strike or CEF or B&Q for that matter. :yes:
  • 2 weeks later...
I had been offerd a  new yale kit 4 (HSA3800) wirefree for £140, which is what got me thinking about getting an alarm in the first place, is this worth it? or am I throwing money away?
40393[/snapback]
Where can you buy the wirefree Yale Kit 4 (HSA3800) from for £140 ?
The only place that I can find that sells it is exclusively at Homebase and its £299.99.
Guest finneganjp
Hi,
Try www.onlineelectrics.co.uk, they supply a range of Texecom gear, cheaper than most online suppliers around :D
Otherwise just pop down to your nearest CEF, I'm sure they will have a full range of Texecom kit. :)
