panel readings
Guest matrix
Nice one Peter AC ma readings are being removed from test sheets.
To check panel current: set leads as above remove fuse from spur (it helps if you have three hands for this bit)
To check current in alarm: as above but get someone to press a panic button (if there is no panic but prog up temporary one or use rkp)
40628[/snapback]
Pete
Only curious and i know you do understand this process. BUT isn’t the panel in eng mode at this stage, as you have lid off? Why not just drop lead from battery disconnecting power then just replace lead causing instant tamper alarm and take reading (no third hand).
Jef
Customers!
