Guest louise0171 Posted February 16, 2005 Posted February 16, 2005 i have a veritas 8 and have opened a sensor to get a spider out and now the tamper button is on and i cant set the alarm, how do i fix this
C.S TEK. Posted February 16, 2005 Posted February 16, 2005 Have you closed the detector properly? You should just have to put your code in to reset as long as your not monitored. chris Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
norman Posted February 16, 2005 Posted February 16, 2005 Press the reset key. Nothing is foolproof to a sufficiently talented fool.
