New bell box to A1 AJ600N
Guest chriscalcite
Guest chriscalcite
My house has a A1 AJ600N installed, which I think was a DIY kit from B&Q? It's worked perfectly for 2-3 years now, but last week when I ran a test there was no response from the bell box (no strobe, no siren). The panel triggers normally and shows the correct zone breached and the wiring at the panel end looks OK.
My first thought was replace the bell box - I always missed the LEDs I had on my previous system - so to that end I have got hold of a Texecom Odyssey 1E. Now on comparing the AJ600N manual with the bell box manual I confess I'm a bit stumped. The bell box manual's fine, but the AJ600N is a bit "connect the green wire to terminal 20" with no real explanation of what the terminals do. Does anyone know how to deciepher what the following six terminals do, and how they might relate to a 'real' alarm system?
AJ6100N -> bell box
Green --- SCB 0
Red ------ bell +
Black ---- bell -
White ---- SCB Rt
Blue ------ Strobe +
Yellow --- Strobe -
Odyssey 1E
A (12V) Permanent +ve supply
B (Bell) -ve applied output to activate siren
C (Tamp) -ve removed on tamper input
D (0V) Pernament -ve supply
S (STRB) -ve applied output to activate strobe
Anyone care to explain how they might be tied together? Or should I just give up and buy a new control panel too? :-)
AJ6100N -> bell box
Green --- SCB 0D
Red ------ bell +A
Black ----  bell -B
White ---- SCB RtC
Blue ------ Strobe +Leave spare
Yellow --- Strobe -S
Odyssey 1E
40671[/snapback]
Yes it would be a good time to get a new more up to date control.
I agree with Normans convertion, and dont forget to relocate the 'Pos' lead from the battery in the Odyssey unit to Batt +, as it's usually 'parked' in a spare terminal during transit... :)
ARJ
A nearly retired previous installer !
Guest chriscalcite
What can I say guys? I went up the ladder this morning, an hour or two of faffing about up there and everything is working 100% with the new bell box :D
Still got the same panel for now, but I shall replace that in the not too distant future for one with an RKP by the front door. At least I don't have to go 20' up a ladder for that!
So thank you very much indeed. I would have been ages trying to figure it out by myself. Your wiring diagram saved me a LOT of pain!
cheers,
Chris
