Help
Scott
:blink:
A Customer has forgotten his password on an early digital Sprite and I be needing access.
Any one know a way round it?
Thanks
Scott
I know on the new ones its a return to DM job, if its connected to a network you can get in with those passwords using network admin.
40917[/snapback]
It is networked, tried ADMIN ----- This let's you into the digis front panel and you still need the password. Doesn't the other other password only change the network access?
Scott
