Guest IspyGaz Posted February 18, 2005 Posted February 18, 2005 Hi all I am looking to change a customers code on a 1995 veritas R8 Ive still got access to to programming to engineering via some dim and distant memory but cant acces the code changes.I know that I could probably manage with the user instructions for this but if they need it reprogramming it could be a stumbling block. Apart form this the panel is servicable and I am loth to change it just for the sake of it thanks Gaz
norman Posted February 18, 2005 Posted February 18, 2005 Try this veritasR8user.pdf Nothing is foolproof to a sufficiently talented fool.
Guest IspyGaz Posted February 18, 2005 Posted February 18, 2005 Try this 40993[/snapback] just a blank page Norman but thanks for the effort Gaz
FASTCAR Posted February 18, 2005 Posted February 18, 2005 There is a user guide for the pre-1999 Veritas in the Gallery , under control panels , and instructions for changing the user code.
Guest IspyGaz Posted February 18, 2005 Posted February 18, 2005 There is a user guide for the pre-1999 Veritas in the Gallery , under control panels , and instructions for changing the user code. 41011[/snapback] thanks FASTCAR jobs a good un just rang the customer who has changed his code appreciate the fast response as the customer had an attempted break in and suspected an inside job with a big do tonight, its a club, by the way have recomended an up grade thanks Gaz
