ian.cant Posted February 25, 2005 Posted February 25, 2005 2 x 1/2" 4mm Auto Iris lenses C or CS mount? Short lead or long lead? P plugged or not?
Guest Guest Posted February 25, 2005 Posted February 25, 2005 C or CS mount?Short lead or long lead? P plugged or not? 41751[/snapback] 1/2" CS Mounted As for the lead the current lens have a lead of 15cm or so, but this is a little too long if anything. (I already have two 1/3" lens purchased from ebay) I think they are P plugged, this I assume is the connection into the side of the camera.. The story is, I had a perfectly good cctv setup around the home that worked from a manual switch that plugged into the TV. I thought that it would be a good idea to connect the cameras to a PC instead, os some other box that I could access over the internet. I purchased a DVR solution that took 4 camera inputs and that also plugged directly onto my network and one that I could access over the internet. Then I bought a dome day/night camera, some cctv enclosures, two vantage cameras, two ir units and two lenses all from ebay. The setup works great except for the issues I was having with the Vantage cameras. As this is my first time with these type of cameras I just could not figure the problems out. The problem is with the fact that I am using 1/3" lenses with 1/2" cameras, hence the need to source two lenses that will provide a clear and "fish bowl free" image. As I am not trade, is there anyone who could here who could provide me with the lenses as an earlier post suggested ? Thanks in advance....
Guest shaundvs Posted February 28, 2005 Posted February 28, 2005 Hi, give me a call during office hours on 0870 4740162, we will try & help out. Shaun
morph Posted February 28, 2005 Posted February 28, 2005 Shaun, I take it that as small trade distributor, you dont mind selling direct to the Public?
