antinode Posted February 21, 2005 Posted February 21, 2005 I've got hold of a few relays rated 240v AC on the contacts and 12v DC on the coil and I'm thinking of using one to switch on a halogen floodlight via the intruder output on a Galaxy panel. Would there be any problems with EMF, as the alarm trigger wire and mains supply wire (fused spur from the lighting supply) will both be close to each other in the relay box? I don't think the relays are sheilded either. Of course I'll be using a diode across the relay coil, but what about induced AC and all that? Sounds like it could cause a few problems at the panel end. Any ideas? Trade Member
Paul P Posted February 21, 2005 Posted February 21, 2005 If the relays are rated at 240v I cant see there being a problem. Paul Trade Member
Guest Posted February 22, 2005 Posted February 22, 2005 Sounds good to me. If you do find there's a problem ACT have a filter for every occasion.
Guest Posted February 22, 2005 Posted February 22, 2005 With my tiny experience with this kind of applications I have never had prob's with the situation you explained.
