Gardtec
Guest Hyte777
Guest Hyte777
Hi Youll,
I'm in Ipswich where can I get Guartec Eurosec from? Gardiner Sec in Chelmsford dont seem to do it.
Hi! nice to see someone local to me ,If you have trouble getting gear try giving spectrum security systems a ring(sss)they are in Colchester the owner used to be a really helpfull guy called Murry, when i was with //.National Installer.// i used to get some gear from them they would order it for me ,i would pay cash plus 5% ish they may still be friendly although they might want the cash up front but if you cant get it anywhere else it could be the solution,regards Paul. :yes:
GardTec's HQ is based in Manchester.
Tel No is 0161 655 5500.
They will advise you of your nearest outlet. However, they may not sell to the public...
If not they will probably advise you of your nearest reputable Installer familiar with the GardTec products, who you can call.
ARJ
A nearly retired previous installer !
Guest ademco1
Hi Youll,
41453[/snapback]
Gardiner tecnology in nottingham on the blenheim ind est in bulwell sell it with free dellivery,the new one comes out this mth which has speech dialer and modem built into it.
regards
:D
