Guest Guest_pete_* Posted February 25, 2005 Posted February 25, 2005 I have a scantronic 9450 panel.Working o.k until a 3hr power cut.Since then I am unable to get it to go into Day mode. The alarm goes of every time we enter the front door (zone 1 ) and is difficult to turn off using access code.Outside box is constantly flashing.The zone 1 light stays on on panel,but will go off if I leave door open and key access code. I have phoned my local security firm but they cannot come out till tuesday!! Any advice would be appreciated. P.S I would use the back door if we had one.
Rich Posted February 25, 2005 Posted February 25, 2005 Where abouts in the country are you? Is sounds like it needs a propper service, I doubt you will get any advice that will help you solve your problem. It sounds like its a perfect sample of a neglected unservised system.
Guest Guest Posted February 25, 2005 Posted February 25, 2005 Where abouts in the country are you?Is sounds like it needs a propper service, I doubt you will get any advice that will help you solve your problem. It sounds like its a perfect sample of a neglected unservised system. 41746[/snapback] I'm in weymouth.Yes thought as much,moved in 5months ago.
breff Posted February 25, 2005 Posted February 25, 2005 Are you sure you arent setting it when you think you are unsetting, and vise versa. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
