Guest Nigel Tuohy Posted February 27, 2005 Posted February 27, 2005 Thanks for that.. What unit is this then and can I get an engineering manual from the web? Nige
Guest Nigel Tuohy Posted February 27, 2005 Posted February 27, 2005 oops yes I did do that but I only needed to reset twice to get out...
morph Posted February 27, 2005 Posted February 27, 2005 so does zone 8 now work as a fire zone Its the older Accenta 8 and yes you might be able to find the manual on the web.
Guest Nigel Tuohy Posted February 27, 2005 Posted February 27, 2005 Ok Ok it works...what can I say... Thank you.... I was confused by the number of resets as it didn't seem to take the code... All I need to do now is find the right manual as I have other issues. Can I just confirm with you, and I appreciate if you don't wish to answer, but to reset this box back to factory defaults I shorted some pins on power-up if I were to say one was on the right somewhere and the other in the middle somewhere.. would I be correct or not... Thanks again Nige
