Nova-Security Posted February 28, 2005 Posted February 28, 2005 Too right I think thats in the 16th edition regs!!!!!!!!!!!!!!!!!!! B) (I'd make a treble wrap just to cover yourself) 41940[/snapback] Can selotape be used in the bathroom ??? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted February 28, 2005 Posted February 28, 2005 Can selotape be used in the bathroom ??? 41996[/snapback] Not necessarily, depends if you're there with someone you know..
Nova-Security Posted February 28, 2005 Posted February 28, 2005 Not necessarily, depends if you're there with someone you know.. 42044[/snapback] Lost the Plot, Selotape somebody you know ? what perversed thing is Georg on about ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted February 28, 2005 Posted February 28, 2005 I meant that if someone has to use bathroom with ANYONE there is not too much protection anyway...
Guest Posted March 1, 2005 Posted March 1, 2005 I think the words "digging" and "deeper" spring to mind! We'll be hearing about Georg and his S&M exploits with sellotape behind saunas in a bit.
Guest dale Posted March 6, 2005 Posted March 6, 2005 Can we get back to the topic guys?? Without knowing what sensor it is, we cant really tell you how to get the lid off. I would try pulling the front (not too hard) as the small hole might just be where the engineer forgot to fit the securing screw. If that doesnt work try placing a small flat head screwdriver where the sensor appears to fit together and try prizing apart. If that fails, carfully try pushing something into the hole as this could release the cover. If all else fails, call an engineer, who will probably bank it off the wall and fit another one. Dale
