external sounder too quiet
Guest sco77ywatty
Guest sco77ywatty
:blink:
When I walk test or do the 05 test thing on my Veritas r8 which I inherited, the internal sounder works fine but the external sounder is very quiet. The manual gives nothing away on whether this is normal but needless to say the volume of the external sounder is next to useless.
Am I missing something? I went up the house and opened the external box expecting an obstruction or something that was muffling it. Everything looks fine.
Will I need a call out? Help please.
You probably need a new bell.
Guest sco77ywatty
41907[/snapback]
do these things generally flounder before going completely?
thanks for your reply
Is the bell box set to SCB or SAB mode? In most new boxes, there's a jumper link on the circuit board to select between the two. SAB is much louder, but it draws alot of current. SCB is much quieter but it does'nt draw as much current. It's usually set to SAB but it's worth checking. In the Texecom bells, the link is next to the battery connection, which you did connect, right? :yes: You may also want to try running the external sounder with the internal one disconnected to see if it makes much of a difference.
Trade Member
Guest sco77ywatty
41913[/snapback]
The lights are down and all is quiet in suberbia.
Perhaps I'll try opening the box tomorrow. I'll let you know how I get on.
cheers
havent got a clue
You said it mate
Mark Hawks
Ex BT Openreach Field Service
