EOL Resistors
Guest dan182uk
Guest dan182uk
Hi all
This is my first post and probably the most stupid but the title really says it all. I have started an apprentiship and have done a lot of fitting of resistors in a variety of panels Scantronic, Galaxy, Texecom etc but have never got how the EOL resistors work and what the panel should see when the zone is closed/open. Any info or diagrams would be greatly appreicated as this sounds really embarrasing as I should know this stuff. :cry:
start with galaxy 2x 1k resistors one across the zone and zone end of line
open = 2k ( panel see`s the resistor across zone and the eol )
closed = 1k ( panel see`s the eol )
tamper S/C 0k short on cable
hi res / lo res panel see`s under say 900 ohm or over 1500 ohm
scantronic 2k2 4k7 as above
now telecom just have an end of line
Guest dan182uk
gotcha its all so simple now :D
Dont understand how I did not know that before :wacko:
Thanks
Dan :D
P.S Is it the same for the 4k7 and 2k2 that in tamper it sees 0k?
Yes, just looking for different values.
41994[/snapback]
err.. why do i have a feeling that 0ohm is zone fault and indefinite is tamper??
(DSC, Guardall, Gardtec, HHL, Esmi)
Guest ALSEC
Hi all
41987[/snapback]
Dan
Not being funny mate but why don't you ask your line manager (or at least one of the other lads)??
If you're doing an apprenticeship then it's your companies responsibility to ensure that you understand how the systems you are installing work.
If there are reasons why you can't ask internally then i'm glad you managed to find out through this site anyway.
Guest oldtimer
Dan
Maybee he has tried and they are playing the old knowledge is power trick on him ?
I agree or maybee his company does not want him to get to clever and leave
Anyway I will give you something to chew over Many moons ago when I worked for Thorn(spit) I worked on a 2 wire eol resistor and diodes sytem (9000_
So any ideas how this system worked and was fully copliant with 4737.
Treat this as the Saturday teasr
why don't you ask your line manager....
42558[/snapback]
They might not know.
hi dan, there is a fantastic book available which will help you with your apprenticeship. Its called "intruder alarms" surprise surprise! author is gerard honey, and the isbn no is: 0-7506-5760-x .
This is an excellent book with nice diagrams. Get it off www.amazon.co.uk
Intruder & Fire Member
Guest ALSEC
Dan
Don't be embarrassed mate - well done for having the guts to stand up and say "I don't quite understand why I'm doing this".
If you immediate boss either doesn't know how to do end of line or does but doesn't want to share the knowledge then you should seriously think about whether you want to stay with that company any longer.
Anyway, I hope you now understand how end of line works.
Ronnie
