fitting box to hanging tiles
Guest roland
Guest roland
hi
i'm going to fit an alarm on my house (i'm a diyer :no: ). but i have hanging tiles from the first floor upwards. has anyone fitted an alarm box (siren) to hanging tiles before? what do you suggest?
any advice appreciated
roland
hi
roland
42268[/snapback]
Get a special tile drill bit
Guest Guest
42269[/snapback]
thank rich!
do you usually fix the box directly to the tiles?
thank rich!
42274[/snapback]
I confess my reply was a bit obvious, but I dont do alarms myself, but im sure someone will answer you soon enough with a better answer.
Guest IM_Alarms
You can use grip-fill to mount something on the tiles to fix to. Cut it to the exact size of the bellbox and weatherproof it. Don't forget to check if the gripfill is weatherresistant too. I've drilled some before and it isn't always successful as some tiles break easily.
Perspex sheet works well. :yes:
Guest Guest
42278[/snapback]
thanks for your reply, that's very helpful :)
if there is a facia board at the top of the tiles i would mount it on that
or better still just forget completely about having an alarm system and employ a security guard with a great big dog :lol:
Ditto to what Pete said but cool the drill bit regularly, I usually take the bell lid up the ladder with me and put a cup full of water in it.
And to re emphasise......DO NOT USE HAMMER.
