andyhodson Posted March 4, 2005 Posted March 4, 2005 Am in need of some accurate fast(ish) help here. I need to change the manager code on a Karizma + panel. I don't have the engineering manuals to hand and they are nortoriously daft anyway. Could anyone let me know how to do this, it will safe me a trip into the office.. Andy Manufacturer
Brian c Posted March 4, 2005 Posted March 4, 2005 It's menu driven. Enter the code and user the arrow keys to find codes. menu 5 i think it is. If you don't know......ask.
Service Engineer Posted March 4, 2005 Posted March 4, 2005 Andy do you know the current managers code..? If not ill PM you some details. ........................................................ Dave Partridge (Romec Service Engineer)
andyhodson Posted March 4, 2005 Author Posted March 4, 2005 Yes I do know the current code, but could do with a walkthrough as its not a panel I'm overly familiar with. Manufacturer
Brian c Posted March 4, 2005 Posted March 4, 2005 Yes I do know the current code, but could do with a walkthrough as its not a panel I'm overly familiar with. 42525[/snapback] Will this do? Karizma_Plus_User_manual.pdf If you don't know......ask.
j.paul Posted March 5, 2005 Posted March 5, 2005 Enter master code, the keypad will show first managers menu option 1)set system? use the the left/right arrow keys to move thought the menus. Press ENTER key to perform a function.. Menu 5 let you change user codes.. when in menu 5 use the the left/right arrow keys to select code to change then press enter, Now key in new code and press ENTER.. (if code is used by another user it will be rejected) Hope this helps EDIT: Ok Brain, so you type faster then me There are no stupid questions, but there are a LOT of inquisitive idiots.
andyhodson Posted March 5, 2005 Author Posted March 5, 2005 Thanks for this. When in menu 5, does one get the option to change the manager code along with user codes? In other words, can you enter the menu system using the manager code and then change it? I have the engineering number if it needs changing using this. Andy Manufacturer
Brian c Posted March 5, 2005 Posted March 5, 2005 Thanks for this. When in menu 5, does one get the option to change the manager code along with user codes? In other words, can you enter the menu system using the manager code and then change it? I have the engineering number if it needs changing using this. Andy 42537[/snapback] I don't know for sure, but I'd assume that entering the menu with the manager code will allow you to change any code except the engineer. Access via a user code would probably allow only that code to be changed. Menu 4 will show you the type for each user. If you don't know......ask.
