Odyssey Bellboxes
Guest Guest
Guest Guest
evening all, Just a quick question.
Does the hold off mode on Odyssey boxes work with control
panels other than the texecom panels ?
thanks.
Depends what you mean. All the functions work with other panels but other panels don't automatically put the SAB into engineer hold off when they're in engineer mode themselves, you have to do it manually.
Guest Guest
42717[/snapback]
Yes, i meant manually.
I have now managed to get an install manual which explains
how its done so thanks for the response.
