Guest Guest_Sparky_* Posted March 8, 2005 Posted March 8, 2005 Hi, I am fitting a new Odyssey 3E bellbox to an ADE optima G3 panel. Looking at the manual(s) i believe the sounder wiring should be; A to +Ve 12v supply B to - Ve sounder trigger C to -Ve tamper return D to - Ve supply 0v S to strobe - Can someone confirm if this is ok or have i got it completely wrong ? Many thanks in advance.
Guest Posted March 8, 2005 Posted March 8, 2005 yes that is correct happy to help just to clear up if it helps panel bell D A B B A D T C more than likeley use - on panel for S B)
Guest Guest_Sparky Posted March 9, 2005 Posted March 9, 2005 yes that is correct happy to helpĀ 43078[/snapback] Many thanks for that
