Optima 2 Plus
Guest Dawn Robinson
Guest Dawn Robinson
After a power cut my Optima 2 Plus keypad has recently defaulted to Factory settings. Can anyone tell me how to reset it so I can input my own exit time?
Please email me at Dawn.Robinson@ncl.ac.uk
Many thanks.
Many thanks.
43135[/snapback]
Dawn,
The entry & exit times are only programable via the Engineers menu, for which you would need the Engineers Code and manual.
Also, if your system failed during a power cut, there is more than likely a problem with the battery or charging circuit. - When was it last serviced ?
I would recommend that you contact a local company and get an Engineer to service it and reprogram it at the same time.
- Post your location and somebody on here will probably be near enough and able to help you.
ARJ
A nearly retired previous installer !
