Guest ghengis Posted March 9, 2005 Share Posted March 9, 2005 Is there a rule of thumb to calculate the approximate LUX level of illumination from a given distance from a street light at night? I assume the illumination decreases inversely with the square of the distance from the light source (e.g. 10 meters from street light = xx LUX). Without I/R light what is the recommended minimum illumination requirement level for a typical domestic day/night camera 0.1 LUX, 0.01 LUX or lower? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/5348-street-lighting-lux-levels/ Share on other sites More sharing options...
ian.cant Posted March 9, 2005 Share Posted March 9, 2005 Without I/R light what is the recommended minimum illumination requirement level for a typical domestic day/night camera 0.1 LUX, 0.01 LUX or lower?0.01 lux in b&w, 0.5lux in colour, thats what i know of the Samsung day/nights.Is there a rule of thumb to calculate the approximate LUX level I have no idea myself, a lux meter is the way to do it if your not sure. Try a bit of googling that might find you a usefull rule of thumb. Generally if there is street lighting there will be enough light for a day/night but clearly that depends how far from a light. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/5348-street-lighting-lux-levels/#findComment-43151 Share on other sites More sharing options...
jb-eye Posted March 9, 2005 Share Posted March 9, 2005 Is there a rule of thumb to calculate the approximate LUX level of illumination from a given distance from a street light at night? 43148[/snapback] Lighting levels are calculated taking into account variables such as reflectance, but i did see today at COP offices a rule of thumb caculation sheet based on different sodium lights used. Ring them and ask. I didn't pay that much attention.Jef Customers! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/5348-street-lighting-lux-levels/#findComment-43182 Share on other sites More sharing options...
Guest ghengis Posted March 9, 2005 Share Posted March 9, 2005 Some googling on street lighting suggests the following levels of illumination ... Rural Night Location = 1 Lux Suburban Street = 5 Lux Town Centre = 10 Lux I was advised that a CCTV camera with a minimum illumination less than one Lux would be OK for residential area covered by street lighting, but I was looking for confirmation of this in real-life. My conclusion is that to be sure that the camera is not operating at its operation limit it would make sense to have a night operation capability with a minimum of 0.1 LUX. There are cameras which can operate at much lower light levels, but perhaps these are beyond the requirements of most residential users. Another point I heard today is that indoor CCTV cameras (such as the Panasonic KXHCM280) should not be used to look outside because if exposed to direct sunlight the camera iris may get damaged? Is this true, or it the only difference between indoor and outdoor cameras the weatherproofing. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/5348-street-lighting-lux-levels/#findComment-43195 Share on other sites More sharing options...
Brian c Posted March 9, 2005 Share Posted March 9, 2005 There is a formula to calculate lux, but I can't remember what it is! If you don't know......ask. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/5348-street-lighting-lux-levels/#findComment-43213 Share on other sites More sharing options...
Adi Posted March 9, 2005 Share Posted March 9, 2005 Outdoor should have an auto iris because of the major changes in light levels throughout the day. I really can't be ar**** with it anymore. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/5348-street-lighting-lux-levels/#findComment-43303 Share on other sites More sharing options...
