Nova-Security Posted March 13, 2005 Posted March 13, 2005 They only sell relays! 43849[/snapback] They dont, and they are a trade supplier, www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Brian c Posted March 13, 2005 Posted March 13, 2005 They dont, and they are a trade supplier, 43859[/snapback] Who? TKC only do modules. And that CPC site is public. If you don't know......ask.
Nova-Security Posted March 13, 2005 Posted March 13, 2005 Who?TKC only do modules. And that CPC site is public. 43863[/snapback] CPC I Agree yep top wack price, fair enough any body in the trade who uses them and pays their prices is not a buisness man/woman (very much like RS ) tooooooo expensive. TK only sell to the trade www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest andyc450 Posted March 13, 2005 Posted March 13, 2005 This ain't about prices for me mate , it's about getting an £8 relay to finish my alarm.
Guest andyc450 Posted March 20, 2005 Posted March 20, 2005 Got the relay thanks brian c Could some one please tell me the setting for the PGM on the panel (Eurosec+vipers)(relay n/c +T). Thanks again.
whibbs Posted May 29, 2006 Posted May 29, 2006 Got the relay thanks brian c Could some one please tell me the setting for the PGM on the panel (Eurosec+vipers)(relay n/c +T). Thanks again. can any one help set a premier 48 panel drive my relays for some flood lights the i have set up would like them come on when the alarm goes then off after 3mins Wayne Hibbs
Guest Posted May 29, 2006 Posted May 29, 2006 can any one help set a premier 48 panel drive my relays for some flood lights the i have set up would like them come on when the alarm goes then off after 3mins wire relay to output, output to follow bell bell, time set by pulse period
cdosrun Posted May 29, 2006 Posted May 29, 2006 Hi, You will need to select your output, and configure it to activate on >Area (select correct area/s) > 00 - Alarm > and then set one of the pulse output attributes on the output, e.g. Pulse 3. Then, in the timer setup, configure Pulse 3 timer to 3 minutes. As far as I know, that is all you need to do. Are you using Wintex or on the panel? I think the former would be easier. Andrew Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
Rich Posted May 29, 2006 Posted May 29, 2006 CPC I Agree yep top wack price, fair enough any body in the trade who uses them and pays their prices is not a buisness man/woman (very much like RS ) tooooooo expensive.TK only sell to the trade Who else do you recomend for components Rich, pref trade only. CPC used to be trade only, RS have everything. It seems there aren't any more trade electronic component suppliers left. Seme, farnell(now CPC) CHS ?
whibbs Posted May 29, 2006 Posted May 29, 2006 Hi,You will need to select your output, and configure it to activate on >Area (select correct area/s) > 00 - Alarm > and then set one of the pulse output attributes on the output, e.g. Pulse 3. Then, in the timer setup, configure Pulse 3 timer to 3 minutes. As far as I know, that is all you need to do. Are you using Wintex or on the panel? I think the former would be easier. Andrew iam using wintex its easier the using the control panel wire relay to output, output to follow bell bell, time set by pulse period will try this and see how it goeswayne Wayne Hibbs
