Guest neo Posted March 13, 2005 Posted March 13, 2005 hi ive managed to get my alarm working apart from when it triggers i dont get any output to the bell i have two red lights flashing constantly when alarm is unset or set but no siren output here is a couple of pics of my board and my alarm i cant seem to get the wiring right
Service Engineer Posted March 13, 2005 Posted March 13, 2005 Panel Bell 12v should goto Supply + Panel 0v should goto supply - and with this bellbox linked accross to either Tamper Terminal Panel "T" should goto the other Tamper terminal The "?" is your bell switched negative **TRIGGER** and the Strobe is your Strobe switched negative **STROBE** ****I cant tell which is which from your pic as the TRIGGER/STROBE writing is obscured from view ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted March 13, 2005 Posted March 13, 2005 You only need 5 wires going upto the bell..? What control panel & bellbox is it..? ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted March 13, 2005 Posted March 13, 2005 r u sure that`s a gardtec bellbox....? ........................................................ Dave Partridge (Romec Service Engineer)
Guest neo Posted March 13, 2005 Posted March 13, 2005 Panel Bell 12v should goto Supply +Panel 0v should goto supply - and with this bellbox linked accross to either Tamper Terminal Panel "T" should goto the other Tamper terminal The "?" is your bell switched negative **TRIGGER** and the Strobe is your Strobe switched negative **STROBE** ****I cant tell which is which from your pic as the TRIGGER/STROBE writing is obscured from view 43908[/snapback] the top trigger is trigger + the next one down is trigger - then its supply + supply - strobe + strobe - tamper + tamper -
Guest neo Posted March 13, 2005 Posted March 13, 2005 the top trigger is trigger +the next one down is trigger - then its supply + supply - strobe + strobe - tamper + tamper - 43912[/snapback] its an accord xpc bellbox
Service Engineer Posted March 13, 2005 Posted March 13, 2005 The "?" is your bell switched negative TRIGGER - and the Strobe is your Strobe switched negative STROBE - ignore strobe +, and trigger + ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted March 13, 2005 Posted March 13, 2005 Panels a Eurosec CP8..? ........................................................ Dave Partridge (Romec Service Engineer)
Guest neo Posted March 13, 2005 Posted March 13, 2005 no idea all i know is its a microtech alarm box
