Guest HiTech Posted September 28, 2003 Posted September 28, 2003 I did a bell test for the fist time in years. Not surprisingly, it didn't ring. After tracing the correct cable/wiring, I decided to measure a few output voltages from the control panel. Here's what I found: In Day mode: BEL = 0V, SCB = 0V In BELL Test mode: BEL = 12V, SCB = 0V I've done a continuity test on all wires and they're fine. Are the o/p's what you would expect? What is SCB used for, because I get different readings when the Tamper switch is activated on the Bell Box, i.e. BEL = 0V, SCB = 5V? The strobe works OK, so is it the control panel at fault or is a new Bell box the answer? Hope you can help.....
Service Engineer Posted October 1, 2003 Posted October 1, 2003 In Day mode you should have: 0 Volts at Tamper Return (SCB T) 0 Volts at Tamper Feed (Hold -) (SCB A) 0 Volts at Trigger (Bell -) 12 Volts at 12V + Terminal (Bell +) In Bell Test Mode, you should have as above but with 12 Volts at the Trigger Terminal. ........................................................ Dave Partridge (Romec Service Engineer)
Guest HiTech Posted October 10, 2003 Posted October 10, 2003 Thanks for your help. It was the bell box at fault.
