c and k 800l+
mikeald
hi all, recently fitted a c and k 800l+ for a mate of mine, all went fine, but now, when he goes to set the system, zone 1 light comes on and stays on (hence system will not set) I have disconnected the front door pair from z1 in the cpu and metered it out and it works perfectly. Any ideas? Panel knackered?
cheers
mike
Intruder & Fire Member
Hi Mike,
have had the same problem on this one. Remove the pair to the contact. Put a wire link across z1 in the panel. If it still does it the panel's had it :smash:
This normally sorts it out, failing that it's a new panel.
CCTV Intruder Access Control
Tony Hughes, Proprietor,
TRADE MEMBER
Guest RICHL
if it is the panel, check for a dry joint on the rear before you chuck it out.
If it clears make sure you dont have a short to the tamper pair
