Guest mark spriggs Posted March 15, 2005 Posted March 15, 2005 Can anyone tell me how to reset the entry exit timer when setting the optima 2 plus alarm system, also when I arm the system and leave, the system bleeps until it sets however when I enter after the system is armed is does not bleep to let you know the system has been activated prior to deactivatingis this normal. kind regards mark
Guest Peter James Posted March 15, 2005 Posted March 15, 2005 Question 1) the exit timer is engineer programming only, you need to call your servicing company for that. Question 2) If you have a contact on your entry door (and you should) then this would normally start the entry noise. If you dont then it may be that the hall movement detector is your entry detector, in which case the entry timer will only start when this detector sees you. Pete
Chris Teague Posted March 15, 2005 Posted March 15, 2005 Also, if you have a contact switch on the entry door it's possible that the contact is sticking & not starting the timer, although if there was a PIR in the hall as Pete suggests & it's not Prog's as your entry zone, I would have expected it to go into alarm when walking into its view. If you have a contact switch on the door, try giving it a few gentle taps to see if this starts the timer, as it could be sticking. If you post your location (town), one of the forum trade members here will probably be able to help you. Regards Chris Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
