DA abacus alarm panel
secboy
I'm sure many of you guys know the DA abacus 15r controls, I need to add splitters to expand the system but have not done so for some time and have miss laid the eng manual can anyone confirm if the panel automatically see's that an existing circuit has been expanded or do you need to do the power up yes*yes trick as with the 8 circuit node Paul. :blink:
Assuming Zone Splitter II is being used.
You need to program the zone to be split, in engineering.
Guest Peter James
Its in the zone programming
44469[/snapback]
Chears for that guys I just needed a memory jogger! :yes: Paul.
